Power Steering
Old Oct 16, 2006 | 11:09 AM
Ronindog's Avatar
Ronindog
Power Steering
To one and all:
I've seen a number of post talking bout useing a 70's era power steering system to upgrade to PS on 66 slicks.
Do other, later model years work as well as far as component transfer, mounting brackets, pulleys etc?
thanks
ronindog
Old Oct 16, 2006 | 11:45 AM
Daplumma's Avatar
Daplumma
Try the search feature,not trying to be smart here but there is tons of great info.The Bendex unit is a straight replacement so you can keep your column the way it is.You will need the pump,brackets,pulleys and hoses from the donor vehicle.The bnedex is not a great unit and is prone to leaking and overheating.
The Ford(Saginaw) system is physically larger and some modifications to the steering column will be needed.The Ford unit is much easier to come by and more reliable.There is much more info in the search section.Good luck!!
Joe
Old Oct 16, 2006 | 12:44 PM
jowilker's Avatar
jowilker
dog, 79 is the last year that things swap. Ford moved the steering gearbox ahead of the axle in 80.
John
Old Oct 16, 2006 | 12:51 PM
Ronindog's Avatar
Ronindog
joe/john
thanks guys'. Big, BIG help.
ronindog
Old Oct 16, 2006 | 03:49 PM
FLgargoyle's Avatar
FLgargoyle
It's been on here before, but do yourself a BIG favor and get components from ONE truck- that way you know everything is compatible. And if you get brackets and pulleys off another engine, use ALL of them. I went nuts buying pulleys and brackets before it occured to me that Ford apparently changed them every year, esp. in the mid 70's. Go ahead and rebuild and paint all the components before installing them. These are big, heavy parts; you won't want to do it twice. The 73-79 front ends are disc brakes, so find a donor and kill all the birds w/ one stone. If you have access to a donor truck, start spraying those components w/ rust buster well in advance of actually trying to unbolt them.
Old Oct 16, 2006 | 09:06 PM
jowilker's Avatar
jowilker
Rock solid advice Jay.
John
