Timing Questions
Old Oct 16, 2006 | 10:41 AM
grasshopper72's Avatar
grasshopper72
Timing Questions
I have a durasparked 1984 2.8l it hesitates a little in the higher gears ( 3rd, 4th), I think the timing is a little off, I was wondering which way it needs to go to correct a hesitation/ stumble (its very slight). Advance or retard, also which way does it need to go to get this, to the firewall or away. I have put a light on it but after it is DS'ed it don't seem to be right at where the light says it should be right. Anyways any help would be appreciated.
Old Oct 17, 2006 | 08:51 AM
TigerDan's Avatar
TigerDan
Hi and Welcome to FTE! Please take a moment to check out the Guidelines as they contain important information that you'll need when posting on the site:
https://www.ford-trucks.com/guidelines.html
Usually you can get away with a little more advance than what is stock, and gain a little pick-up. The more it's advanced the better it will generally run until you get into detonation (pinging) and hard starting, that's where you know you need to back it off a little. As a general rule, with the engine idling you turn the dist. and if the idle speed increases then you're advancing it, if it slows you're retarding it. Of course, the vacuum needs to be disconnected while adjusting the timing when setting to spec with a light.
jackler
Apr 19, 2011 08:47 PM
Jitterbug
Jul 26, 2010 06:50 AM
dkoenig
Feb 16, 2007 11:04 AM
zstar5000
Bronco II
Dec 2, 2006 11:03 AM
ITDave
Modular V8 (4.6L, 5.4L)
Sep 27, 2003 03:43 PM
