Blower motor replacement
Old Oct 16, 2006 | 10:27 AM
Caplax40's Avatar
Caplax40
I'm going to change out the blower motor this weekend, in an attempt to fix my heat/cold issues.
I did some searching on here and it looks like the aftermarket motors do not come with the wheel and they require some wiring (?) to get working. Is this an accurate assumption?
If so, does Ford sell a blower motor that is just plug and play without any wiring involved?
Old Oct 16, 2006 | 04:20 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
There are only 2 wires for the aftermarket motors just like the motor you have now. The wires from the aftermarket motor are not inserted in the connector because one motor may fit mulitple cars which may require the motor to turn a diffrent direction. You will have to remove the old blower wheel off the old motor but that just involves 1 bolt.
