No rear heat
Old Oct 15, 2006 | 09:28 PM
IHdieselfan's Avatar
IHdieselfan
No rear heat
my explorer has no hot air out the rear vents. the a/c work fine in the rear. is there a valve in the heater hose to the rear.
Old Oct 17, 2006 | 12:09 PM
l-m tech's Avatar
l-m tech
if you are getting a popping noise when you try to change the temp you will need a temp blend door actuator.
Old Oct 21, 2006 | 09:48 PM
IHdieselfan
no popping noise, is the blend door controled by vaccum
