Instrument Cluster
Old Oct 15, 2006 | 07:53 PM
Firemut30's Avatar
Firemut30
Instrument Cluster
I tried searching for any info on instrument cluster removal and have found nothing. Does anyone have the proper way to take apart your dash to install a new dash face?
Also I saw an idea on here to make a folder on all this remove and replace info and pictures. I checked under Articles/Specs and it looks close to it but has alot of other info also. Thanks
Old Oct 15, 2006 | 08:06 PM
ohboy44's Avatar
ohboy44
Take off the trim panel under the steering column, then take the 2 screws out at the bottom of the cluster trim panel, then push it straight up to pop it loose from the clips that hold it in across the top. 4 screws hold the cluster in, if it's a column shift you can depress the clips on both sides of the PRNDL and it will slide out.
