turn signals help
Old Oct 15, 2006 | 03:43 PM
7salinas3's Avatar
7salinas3
turn signals help
I have a 73 f100 s/b , the turn signals will work when the truck is not running and the key is off . How can I fix this . any info will help . also what color is the wire for the back up lights?
thanks
new user
Old Oct 15, 2006 | 04:05 PM
western star's Avatar
western star
This is a new one on me but any signall problems I have had have always been bad ground issues solved by replacing corroded pigtails
Old Oct 15, 2006 | 04:10 PM
Mil1ion's Avatar
Mil1ion
Bad ignition switch.
Backup light wire ?
Where at...?
the NSS on the column
or
at the back of the truck ?
Old Oct 15, 2006 | 04:23 PM
7salinas3's Avatar
7salinas3
thanks for the reply guys do you think yhe ing. switch is wired wrong? back up lights will not come on bulbs good dont know where the problem is.
Old Oct 15, 2006 | 04:25 PM
Mil1ion's Avatar
Mil1ion
Well if the switch is faulty and allowing power to the TS circuit then it is probably a positional thing.
How about the hazard lights..do they work with the key on or off ?
Old Oct 15, 2006 | 04:46 PM
7salinas3's Avatar
7salinas3
the hazard switch is missing , the p/u was non p/s p/b I did the cross over if i remember the old colum did not have that option.
Old Oct 15, 2006 | 05:09 PM
Mil1ion's Avatar
Mil1ion
It should still have a hazard light switch on the dash regardless of the options.
What is happening is you're getting power to the TS switch when you shouldn't be.
The ignition switch is the thing that usually gets it there.
You need to find that source of power.
Maybe remove the ignition switch and do a fault test on it.
This one is for a 78....Yours will be different.
http://www.clubfte.com/users/mil1ion...nFaulttest.JPG
Old Oct 15, 2006 | 06:01 PM
7salinas3's Avatar
7salinas3
i'll do the fault test and get back to you some time in the week thanks for the info
