Sponsored by: Real Truck
Need help from expert...FAST
Old Oct 14, 2006 | 03:03 PM
markbrumbaugh's Avatar
markbrumbaugh
Getting ready for maiden voyage on motorhome. Sits on an E350 with dual rear tires and disc brakes. I noticed a leak of oil that appears to be coming from between the discs on the driver side. What is going on?
Old Oct 14, 2006 | 05:11 PM
vloney's Avatar
vloney
first thing that comes to mind is axle seal leak.
Old Oct 14, 2006 | 05:14 PM
markbrumbaugh
I think you are correct. Can I drive it a couple hundred miles like that?
Old Oct 14, 2006 | 11:10 PM
kbeefy's Avatar
kbeefy
it's on the back right? How bad is the leak? is the inside of your rims and tires coated? Or is it just a little wet. If it's nasty all ove rhte inside of your tire I'd fix it, if the hub/axle was just a bit wet it should last till you get done w/ your trip.
