Just Bought One Off Of Ebay It Is Out Of A 01 Model It Is 75 Hp I Have Never Chipped Anything Before And Never Had A Diesel I Have Always Built My Horsepower Without A Chip I Love Building Big Horsepower Small Block Chevrolets As For The Chip I Dont Know Where It Goes How To Install or If The Difference In Years Will Matter Any Help Will Be Appreciated
If it is just a regular chip it plugs into the side of the computer. The computer is on the drivers side kick panel. It has a black cover over it. You will have to pull the cover off.
Here is a link from ITP diesel for a DP chip install. Same for the TS. What year is your truck? TS was not as specific about what truck/PCM you have as DP Tuner which leads me to believe it is a more generic tune and you should be OK. That does not mean it will not make her move if you got one that will work for your truck. I usually tool around in the 75HP setting when I'm just generally trolling for suckers. Never know when I might want to crank it up though.
With a generic chip you shouldnt have a proble as long as it was for the 7.3. You might want to look into the Intake, exhaust and also some gauges. with a chip the EGT's can climg rather fast.
