removing door panel
Old Oct 14, 2006 | 11:57 AM
5.0 ford's Avatar
5.0 ford
removing door panel
How do i take off the passenger side door panel? i have manual windows and locks. The lock pin is gone and i want to replace it.
Old Oct 14, 2006 | 03:16 PM
thefonz#1's Avatar
thefonz#1
There's several screws you need to remove depending on year and make. The window crank can have a clip behind it, my '92 ranger has a cover over the window that snaps out of the way to allow access to the screw. Usually 1or2 screws in the arm rest. After removingg all screws, again depending on year and make pry the panel out. It snaps it with clips. Some newer fords the panel pulls straight up instead of prying it out.
Old Oct 14, 2006 | 04:18 PM
5.0 ford's Avatar
5.0 ford
i got it but broke some fasteners, oh well. My pin must have broke off the top cause the lock wire fell inside the door.
