1978 - 1996 Big Bronco
Cruise control servo location
Old Oct 14, 2006 | 11:41 AM
autx790's Avatar
autx790
Can someone please tell me where the "little black box" that holds the cruisecontrol servo is. I'm pretty sure mine is shorting out on me but I don't know where it is.
Thanks,
Peyton
Old Oct 14, 2006 | 12:14 PM
33boggers's Avatar
33boggers
in the corner next to the brake booster. you should see the cable running to it form the throttle body.
Old Oct 14, 2006 | 02:53 PM
McLeod's Avatar
McLeod
Just follow the cable to it. Most are near the master cylinder.
Old Oct 14, 2006 | 03:29 PM
autx790's Avatar
autx790
Thanks guys, I found it, pretty obvious :/
Second question.
I've read people have had to replace this because of shorts caused by the sensor recall on the master cylinder. My plug going into the box is all melted around the first two wires (red and light blue, and black with yellow stripe). when my sensor that was replaced is plugged in, my fues (#13 blows). when I had the cruise control assembly plug hooked up today it started smoking real bad, but none of the internal electronics seem damaged. Any idea to what could be causing this short. I'm planning on going to get a new wire harness plug and replace the cruise control servo assembly, but just wondering if anyone knows if this could be a separate issue and i'm going in the wrong direction. Any info would be appreciate.
Thanks
Peyton
