I'm going to try and fix a crack in my transmission case with some jb weld, but would like alittle info before I start.
Ok, it says allow 4-6 hours to setup, does this mean mix it, and wait 4 hours before I even put it on?
Also, what is the best thing to use to clean the surface. I steel wire brushed the he*l out of it, but I've heard to use some carb cleaner and acetone, which one would be better?
Also, what should I mix it in and with?
Use whatever your heart desires to clean it, but AFTER you apply the JB Weld allow it to sit for at least 4-6 hours. If it was me I would let it set for a day or two before driving it.
I have used a popsicle stick to mix it, then just through it away when done, it can also be used to apply the j-b weld. If you wait to long it will be hard as a rock, so once mixed use it right away
to clean, acetone, or brake clean works good also.
mix with a popsicle stick, or sometimes i will use a small screwdriver. mix on a piece of cardboard. if using the screwdriver, clean well as soon as you are done, or it will be ruined after hardening. let sit for at least 24 hours if you can.
I ended up using a tooth pic and a paper plate to mix it, and put some on, and I'll let it sit till tomorrow around the same time, and try and add some more.
there's also JB Weld and Quicksteel (my favorite) putty stick....just kneed between your fingers and apply....holding my Galant's oil pan together well.
I have been using the Quicksteel and am pleased with it. I repaired a hole (not rusted) that was knocked into the floor pan and it did the job quickly
JB kwick weld>quicksteel putty... That stuff's pretty hardcore rancid smelling. Like opening a junkyard car on a hot summer day's the best way I can describe it... It's NOT a plesent smell, but it's a good product otherwise.
A little latenight backround...
I used some to fix the mirror on my F150, about 20 min before I had to leave for a date. My hands were raw from scrubbing, but still werent back to normal. It was kinda hard to explain the smell
Skuff it first with some sand paper, then clean the area with brake cleaner to remove any grease before applying the JB weld
~Nate
I prefer Fiberglass Bondo. I have some plugging a vacuum leak in my minivan's intake plenum right now (mating surface got dinged)--it's been holding for 18 months plus now.
Drain the oil, replace the cap and dipstick and stickweld that badboy! I ground through the pan on my ole racetona after I hit a dip on uneven pavement, and my bud fixxered it no problem.
JB weld is just epoxy with a filler material. Use a toothpick or popsicle stick to mix it on a clean piece of paper or cardboard etc. DO NOT use the same stick to apply it. Use a fresh stick and DO NOT scrape the plate or cardboard mixing surface. There is always some unmixed or improperly mixed material on the stick or mixing surface that will not cure properly.
The JB weld will not fix a crack if there is any stress on it.
well, paranoia (and good prices on rockauto) encouraged me to change my Galant's pan today...and you know what? NO SLUDGE running on ST dino oil....gotta love that....
did slap some thermo steel on the resonator and some quick steel on the muffler.....
