223 Head differences?
Old Dec 29, 2002 | 05:33 PM
bhabben's Avatar
bhabben
Folks,
Is it true that later 223 heads are higher compression? How much? Also, how can you identify these higher compression heads? What applications had them?
Thanks,
Brett
'59 F100 223
Old Dec 30, 2002 | 01:17 PM
286merc's Avatar
286merc
Unfortunately you wont be able to do a head swap and gain anything. The block changed in 61 to 1/2" head bolts.
The 60 head had the same cr as the 59 but used a different valve cover.
Im guessing here but maybe Ford had head sealing problems since they werent into spending a penny if it wasnt necessary.
Old Dec 31, 2002 | 09:07 AM
54_5star's Avatar
54_5star
The chanbers are smaller on the later heads ( late 50's and on ). I wasn't aware of a head bolt change. If there was a change in '61, then look for a '57 to '59 head. They won't have any valve cover screw holes, as the valve cover is still held down with the two studs like the earlier ones. The chambers are kidney shaped and have a lot more quench area compare to the earlier chamber shape which kind of triangular.
Old Jan 3, 2003 | 07:05 PM
bhabben's Avatar
bhabben
Thanks for the info. In the event that the later head with 1/2" bolts is the hot ticket, can I drill and tap my '59 block to 1/2" to use the later head?
If not, could I mill my existing '59 head, and if so, how much?
Thanks again...
Brett
Old Jan 4, 2003 | 10:50 AM
286merc's Avatar
286merc
Im afraid my knowledge of 6 bangers is limited to before and after yours.
Why not swap in a later model and have all the advantages?
Old Jan 7, 2003 | 01:31 AM
55FordLover's Avatar
55FordLover
Old Jan 10, 2003 | 12:12 PM
54_5star's Avatar
54_5star
If you already have a '59 head, there isn't any reason to go any newer. That's about the pinnacle of performance for the 223 ( the word performance being used loosely ). They have around 8.6 to 1 compression. According to my books the highest hp rating was in '57/'58 with about 145 hp. Early 60's have a little less with 138 hp. My books have the hp numbers for car engines. I think trucks were usually advertised with 138 hp so may not have quite as high a compression ratio. You could mill your head for more compression, but in my experience 223's tend to ping a little with the compression they already have.
Cazman1955
1961 - 1963 F100 Unibody
Mar 22, 2013 09:28 PM
brider
Nov 5, 2007 10:30 PM
oldsenile
Apr 8, 2005 01:42 PM
julie 54
Aug 22, 2002 05:56 PM
shermantank
Mar 12, 2002 01:17 PM
