Bronco II Ford Bronco II
Basepan
Old Oct 13, 2006 | 10:48 AM
Dryfire152's Avatar
Dryfire152
Cool Basepan
I need to change my oil pan gasket on my 88 BII four wheel drive. All Data requires me to remove the distributor, disconect the muffler inlet, stabalizer and so on. Than raise motor to get at the base pan. Is there a better way to change that gasket or should I just keep adding oil?
Old Oct 13, 2006 | 12:35 PM
Help I M Stuck's Avatar
Help I M Stuck
getting that oil pan off completely is no easy job. you pretty much need to pull the motor to get it off.
Old Oct 13, 2006 | 03:18 PM
rebocardo's Avatar
rebocardo
You can get the pan off by raising the vehicle's frame so you get axle droop, then lift the motor/trans/xfer as one unit to slide it off. Putting it back is another thing.
I do think on a BII it is much easier just to pull the entire engine out the front of the vehicle after removing the radiator.
Old Oct 15, 2006 | 10:26 PM
Dryfire152's Avatar
Dryfire152
Thanks, I think I will just keep adding oil when needed. It does not leak much anyways. Next Aug, I will start a collage program for diesal and high performance engines. My 2.9 will be my project for a rebuild. I know its small, but I will find anything to raise the fuel milage and power. Any sugestions on aftermarket parts would be great help. I realy enjoy my BII, so I am slowly going to fully restore it with a little bit of mods here and there.
Old Oct 16, 2006 | 07:32 AM
OSin86's Avatar
OSin86
Here you go, just about everything you'll need to know if you do it.............
https://www.ford-trucks.com/forums/s...0&postcount=20
Harley Hill
Nov 11, 2016 11:25 AM
Moonpie6899
May 22, 2016 10:59 PM
Kyle Campbell
Apr 13, 2016 08:56 PM
mytruckisolderthanme
Mar 23, 2013 08:46 AM
QuangUS
Bronco II
Mar 8, 2003 06:20 PM
