Power seat issue
Old Oct 13, 2006 | 09:50 AM
BP57's Avatar
BP57
Power seat issue
On my '04 EB my driver's seat will move backwards when I take the key out to make it easier to get in and out. But lately, its not going back to its preprogrammed spot when I put the key back in. Something is clearly wrong but I just can't tell where the problem lies. Sometimes it moves a little bit, sometimes not all and sometimes it works fine. Inserting the key over and over gets it to work once in a while. Other times, I have to manually move it. And once, not even using the levers to move it worked for a little bit.
Is it the motor? Loose wire? Bad connection in the ignition? Any thoughts? Where should I look?
Old Oct 13, 2006 | 10:07 AM
hoss1636's Avatar
hoss1636
Ford has a tsb on this if I remember correctly it is either the seat motor potensiometer or the module depended on the issue, both have similar issues just minor details in the diagnosis to determine wich one
Does the memory mirrors act up?
Old Oct 14, 2006 | 07:54 AM
BP57's Avatar
BP57
I'll have to check on the mirrors. Not exactly sure but I don't think so. Unfortunately, I'm out of warranty. Can you post a link to the tsb?
