Stumped on rotors...
Old Oct 12, 2006 | 05:31 PM
5004man's Avatar
5004man
Im trying to figure out how to get my rotors off but cant get past my hubs! I have automatic hubs and im a little confused on how to get them out, I have searched for the past couple nights, and have only found stuff on manual locking hubs, Im just not seeing it I guess. If anyone can simply explain it, or know of a write up it would help me a whole lot. Thanks
Old Oct 12, 2006 | 05:56 PM
bohiaa's Avatar
bohiaa
there was a post on this several months ago...
cant remember where it was But It was mistitled.
there IS a trick to it.
sorry I could'nt be more help
Old Oct 12, 2006 | 07:21 PM
lostin90s's Avatar
lostin90s
After you take outer hub off (3 0r 6 bolts)there is a groove in outer rotor/hub it is a wire like retainer find end use 2 small screw drivers to pry retainer out. your way around till comes out. It May take you awhile to get it off ,Now remove center snap ring and (may or not have) C-clip on axle . Inner hub assembly should come out. I just did this to my truck to lube f-bearings for winter. Good luck
__________________________
94 F150 4x4 Xlt SC LB Maf 302 E4od
