1966 - 1977 Early Broncos
Exhaust leak???
Old Oct 12, 2006 | 12:04 PM
chefddh's Avatar
chefddh
Exhaust leak???
I have a leak in my exhaust where the muffler pipe joins the headers. I have looked at it and the gasket needs to be replaced. before I do it do I junt need to replace the collector gasket and that is it? Do i use any RTV? Thanks.
-ddh
Old Oct 14, 2006 | 02:30 AM
mauicruza's Avatar
mauicruza
I've always had the same problem with collector gaskets but couple of things I started doing really help it last alot longer. Always use a good quality brand and make sure your flange rings aren't bent from over tightening. Also check the lip on the header and the collector to make sure it has not eaten away from corrosion.
