General Automotive Discussion
Tach/dwell
Old Oct 11, 2006 | 09:42 PM
thefonz#1's Avatar
thefonz#1
Tach/dwell
I wasn't sure wich forum to put this in, but I knew the 61-66 would cover points.Anyhow, I need to check dwell and rpm on a....., um,..... um...... ,chebby (not mine,ha ha) I'm getting old and my memory isn't what it used to be. My tach/dwell meter has 2 wires, one green and one black.
I haven't used it for probably 20 years or so and I can't remember for sure how to hook it up. I think black goes to ground and green goes to pos. side of coil. Is this correct? I actually thought it was the neg. side but figured I was wrong.
TIA!
Old Oct 11, 2006 | 09:51 PM
FordBoypete's Avatar
FordBoypete
If green wire is the pick up side & black is ground, green should go to the - side of coil which gives the "break" or Dwell time in degrees the points are open. It is also the side that fires the coil to power the ign spark through the cap. . . .
If what's left of my mind is correct & the Blowtie is an 8 cyl you want between 28-32 degrees of dwell with 30 deg being the median
FBp
Old Oct 11, 2006 | 09:59 PM
Bdox's Avatar
Bdox
Right on Pete.
And if you are lucky the distributor cap might have one of those little doors on the side so you can adjust the points with an allen wrench while it's running.
Old Oct 11, 2006 | 10:15 PM
thefonz#1's Avatar
thefonz#1
Thanks guy's, like I said I thought it was the - side, but the more I thought about it I doubted myself. Yes the chevy has the "door" on the distributer.
xtal_01
16
Dec 9, 2016 06:41 AM
JEFFFAFA
May 26, 2015 10:10 AM
68horses
Oct 2, 2009 02:55 PM
cole_boy
Garage & Workshop
Jan 29, 2003 07:45 PM
bluemustang
Dec 11, 2002 04:25 PM
