Sponsored by: Real Truck
Difference in FX4 and Standard 4x4
Old Oct 11, 2006 | 09:27 PM
roderplex's Avatar
roderplex
What are the differences between the two suspensions? Is this all that is different? It appears that it is just shocks; what brand are they?
Thank you,
Russell
Old Oct 11, 2006 | 09:55 PM
Dustin1690's Avatar
Dustin1690
Well the difference is they got fancier suspension everything uprgraded for off road i maybe wrong but i believe they use rancho shocks they also put in skid plates and stuff kind of give you an idea you also can go to ford's website and build a truck and when you choose that option (FX4) it tells all the information on it
slisty's Avatar
slisty
The shocks and the FX4 has skid plates for the fuel tank, trans, and motor. The shocks I think are ranchos.
Old Oct 11, 2006 | 09:59 PM
a-rod's Avatar
a-rod
And dont all the FX4's have a limited slip rearend? also a front steering stabilizer shock.
Old Oct 11, 2006 | 10:28 PM
bf250's Avatar
bf250
there is NOTHING! different!
come on now, there is nothing worth noting different between the 2. some cheesy shocks, xfer case and fuel tank skid plates, and cute little stickers in the back that say fx4.
the fx4 is just a little cute gimmick for ford to make a little extra money off of, it won't make you any better off road or anything. same springs, axles, even shocks pretty much.
the skid plates are good if your worried about smashing the xfer case or fuel tank on something, but you can order those as an option.
Old Oct 11, 2006 | 11:31 PM
TremecGT's Avatar
TremecGT
There is a difference, its a cheap upgrade and it gets you skid plates so why not. If you dont like the sticker, then take it off.
Old Oct 11, 2006 | 11:52 PM
tvsjr's Avatar
tvsjr
I got the 4x4 truck and the skid plate package. Saved a few bucks, esp. since I knew the "Rancho" OEM shocks were crap.
Old Oct 12, 2006 | 02:06 AM
Deluxe05's Avatar
Deluxe05
From the '06 & '07 Order Guides (also included within the Super Duty Options page on Ford's website):
FX4 OFF-ROAD PACKAGE (55F)
Availability:
  • Requires 4x4, All-Terrain tires and Limited Slip Axle
  • NA w/Harley-DavidsonTM Package (17H)
Includes:
  • Transfer case and fuel tank skid plates
  • Rancho branded front and rear shocks
  • "FX4" decal
It is pretty safe to say that the majority of folks that cruiser the Super Duty sections here on FTE will advise that you skip the FX4 package & just get the skid plates. But, like everything else, it is up to the buyer to decide if it is worth the money.
FX4 package - $225 MSRP - $187 Invoice
Skid plates - $100 MSRP - $83 Invoice
Old Oct 12, 2006 | 08:06 AM
daveshan's Avatar
daveshan
I got the FX4 package because the truck that fit my needs in all other ways and was on the lot had it on it along with one other option I never use (power pedals)
The shocks were dumped at 6K mi for Bilsteins because the "Rancho" units coldn't control the weight of the wheels on the dirt roads around here and I was bouncing all over the road at any speed. The sticker was taken off long before that, the truck looks much better without it IMHO.
If I was to order a new truck I'd go with skid plates and the LSD option.
Old Oct 12, 2006 | 08:48 AM
a-rod's Avatar
a-rod
how come all the fx4's i see have a limited slip rearened?
Old Oct 12, 2006 | 09:31 AM
4xsport03's Avatar
4xsport03
Mine has the FX4 package because I belive it came with the sport package. I removed the FX4 sticker and replaced it with an '03 F150 4X4Sport sticker. The 4X4Sport sticker looks much better on the truck than the FX4 did.
Old Oct 12, 2006 | 10:39 AM
Lonewolftx's Avatar
Lonewolftx
Arrow Huh . . .
Note comment from Deluxe 05 above for the insight . . .
Old Oct 12, 2006 | 12:22 PM
ffemtp's Avatar
ffemtp
I talked to a Rancho tech (at Rancho) asking for part numbers to the FX4 package. He said the OEM were as good as the Rancho's and I would be better off buying Rancho 5000's off of the shelf. My intentions are to put Bilsteins on mine.
