8.8 axle differences
Old Oct 11, 2006 | 09:16 PM
94broncoxl's Avatar
94broncoxl
I read in another thread that an 8.8 from a van wouldn't work in an F-series. Wandering if this is really true and if so, why? Is the Bronco the same as an F-series or are they all the same. Just curious.
Old Oct 11, 2006 | 10:17 PM
aurgathor's Avatar
aurgathor
I think van axles are a bit narrower.
The Bronco is essentially a very short bed F150 with a big cab, and so with the exception of a few parts, mostly body, it's identical to the F150.
Old Oct 13, 2006 | 12:15 PM
fattmann's Avatar
fattmann
From what i was told doing research for my axle swap the E-series frame rails are actually wider. Was advised not to use an F-series axle on my van as the spring mounts would be too narrow. Never had an F-series to measure so don't hold me to it.
As for overall width, wheel to wheel? Have no idea..
Old Oct 13, 2006 | 12:24 PM
rearendman's Avatar
rearendman
Van frames can be up to 6 inches wider; depending on yr; stay away from swapping van housings with F series; you are asking for a lot of work;
Old Oct 13, 2006 | 04:44 PM
94broncoxl's Avatar
94broncoxl
Thanx, for all the input guys.
