Big truck question
Old Oct 11, 2006 | 08:20 PM
F6Guy's Avatar
F6Guy
Big truck question
I have a truck calender with a '39 1.5 ton with a factory pick up bed. In the discription of the truck it mentions that in 1939 ford offered a twin engine cab-over tractor truck. My question is has anyone hear ever seen one or has any other info. Im just curious, I looked for some info on the net and came up with nothing. Thanks in advance for any help.
Old Oct 12, 2006 | 10:11 AM
46fordtruck's Avatar
46fordtruck
The twin engine was actually made by an aftermarket company. It was made by a company called Grico, which converted Ford trucks for heavier use. The Grico Twin-Motor Tractor, as it was called, used 2 239 CI flatheads. One was in the stock location, and the other was mounted in a box behind the cab. That second engine powered it's own drive axle, so the truck had twin rear axles. The engines could be used individually or together.
Old Oct 12, 2006 | 10:16 AM
seventyseven250's Avatar
seventyseven250
that must have been some setup! Couldn't you end up with the situation where the two engines were trying to run at different RPMs and then one would be engine braking against the other?
Old Oct 12, 2006 | 10:19 AM
46fordtruck
The manufacturer said they could be run together through single contols to keep them synchronized. I'm sure the truck had to come to a complete stop for the engines to be run together at the same time. I just wonder how many of these were made, and how many, if any, still exist.
Old Oct 12, 2006 | 06:56 PM
F6Guy's Avatar
F6Guy
were did you find your info? Do you know were there are any pictures. Thanks for your help that is very intresting.
Old Oct 12, 2006 | 08:30 PM
46fordtruck
I was digging through a book I have here on truck history. There is only 1 mention of the Twin-Motor thing. I have another book, a very rare book, called Hildy's 1947 Blue Book of Special Equipment that lists various aftermarket firms that modified Ford trucks when new. In this book, Grico makes no mention of the Twin-Motor setup, so perhaps this was a very short lived conversion, maybe the War brought an end to the Twin-Motor conversion. The only pic I have seen of the Twin Motor was a front 3/4 view of a '39 Cab Over. The truck had dual rear axles, and a metal box with some louvers mounted to the frame right behind the cab, but that's about it.
Old Oct 13, 2006 | 03:58 PM
F6Guy's Avatar
F6Guy
Thank you that is some wild stuff. I guess by that time diesels were starting to come into there own and the factories were starting to make bigger gas burners such as GMC and so on.
Old Oct 29, 2006 | 05:14 AM
BADCAR's Avatar
BADCAR
Twin Engine Ford Trucks
GIRCIO made the Twin Engine FORD Trucks--Henry Ford built the WW11 B-24 Bomber & the GIRCIO twin engine Ford cab over was used to Tow the finished B-24s out of the Factory--I inquired on the {FORD BARN} & a few Ole FORD Guys replied w/ Info & Photos--ONE was Towing a New B-24 Bomber & another showed a Wider than Stock regular Cab w/--an extra Wide Hood & an added piece in the Windsheild--hauling Lumber?--w/ Twin Rears!--& pretty well Beat Up?--as it looked like it had hauled many loads? I saw ONE in Pittsberg,PA out behind a Steel Mill--a 39 Big Ford w/ twin rears--I tried to take a Look! but Couldn*t open the Dam HOOD! so I Dono? what? the Engine Compartment looked Like?--but there were Two Oil pans where only ONE should Be!--it was Exactally like the Reg Cab shown on the Ford BARN 39 Ford Green in Color!--Ole JIM--
Old Oct 29, 2006 | 05:43 AM
joes52f6's Avatar
joes52f6
Guys go to http://www.hankstruckpictures.com/bernard_johnson.htm I seen these trucks on there and thought It was a homemade job or something. Check it out and see if it is any help. Joe
Old Oct 29, 2006 | 05:47 AM
joes52f6's Avatar
joes52f6
I'm pretty much a regular on this site also, but these trucks sound like the ones you guys are talking about. Joe
Old Oct 29, 2006 | 04:46 PM
46fordtruck
Joes52f6, those are some neat machines there. Not quite the Grico Twin Motor. The Grico conversion had a seperate engine mounted out behind the cab and dual rear axles, and were V8s. Still those are some impressive machines, 2 engines sharing one bay, appears to be a pair of flathead 6s.
Old Oct 29, 2006 | 07:12 PM
joes52f6's Avatar
joes52f6
Yeah I just noticed earlier that they was a little different from the description you guys had, but I wondered if ford might have went solo on these two engine trucks? I just wondered how long these trucks would have lasted before getting faded out so to speak?? JOE
Old Oct 29, 2006 | 07:32 PM
46fordtruck
Seems more like these were attempts by Ford (and other makes I am sure) to get into the heavy hauling market. They seemes to have been around a short time, looks almost as if WWII was the last of some of these extreme engine setups. Diesel I'm sure was soon found to be able to get the job done, with out the huge amounts of fabrication and costs of running a truck on 2 engines.
Old Oct 29, 2006 | 07:54 PM
joes52f6's Avatar
joes52f6
GMC coe trucks in the 60's and even 70's used a v-12 gas engine in there class 8 trucks and from what i heard got better mpg than diesels but in the 70's they was having there gas shortages and such so they justed faded into the background as well. It would be cool to see trucks like these though, pain to drive i bet! JOE
Old Oct 29, 2006 | 08:50 PM
merlynr's Avatar
merlynr
my step-father was an independent trucker in the 50's and hauled steel with an International KB7 and it had a gas engine of about 400ci and he got about 4 mpg with it loaded. All the truckers called Internationals "binders". I suppose because IH made harvesters etc.
