Edge Evolution tunes......
Old Oct 11, 2006 | 07:58 PM
Lawson4x454's Avatar
Lawson4x454
Question Edge Evolution tunes......
Has anyone tried a custom tune of their own? What did you do different and how did it preform??
Old Oct 11, 2006 | 09:14 PM
DASTUD's Avatar
DASTUD
I customized the performance level a little bit, bumped up the shift firmness a couple of points and timing. Overall, no difference than the stock performance setting unless at full throttle, and then you can tell the difference from shifting through the gears. I did not want to mess with it to much.
Old Oct 11, 2006 | 10:05 PM
grant5127's Avatar
grant5127
I've only had mine a couple of weeks and have not had time to mess with it.. but this Saturday I'm gonna give it a try...
TxOutlaw05's Avatar
TxOutlaw05
Yeah, same here, just the shift firmness on Level 2 and 3... I think just the regular tuning helps everything a ton as it is, especially in my 4.6L SCrew 4x4...
Old Oct 17, 2006 | 02:32 PM
InboundFX4's Avatar
InboundFX4
I use Tow and Performance tunes with +8 shift firmness. I tried -1 on shift rpm (cant remember what exactly it's called) in an effort to save a few bucks at the pump but that just made the truck accelerate slower. Now I'm back to just the +8 shift firmness and that works best. Oh, and I have the tire size corrected but I may change that since the speedo is off by 5-7 mph.
