pinion gear spining
Old Oct 11, 2006 | 03:14 PM
HUCKSTER-USA's Avatar
HUCKSTER-USA
Angry pinion gear spining
after winding first gear out to 4000rpms gettn ready to hit second, mr policeman showed his face and i instantly took my foot out it still in first gear... as soon as i did this i felt and heard what sounded like gears being grinded, stripped. popped into neutral and everything was fine. put back into drive everything was cool, when goin down hill though i'd feel a vibration as the gears were holding the truck back goin down the hill, i'd put my foot back into it and the vibration would go way. now at home i had my wife jump into truck put into reverse with foot on brake giving it some gas the pinion was spinning makn all sorts of noise i wouldn't wish on anyone. is this the splines on the axles or the pinion gear its self? should i just plan on gettn a new 3rd member with axles. i have 4:88 gears with a spool turning 39" boggers
Old Oct 11, 2006 | 08:37 PM
andym's Avatar
andym
Pretty tough to say - there's really only one way to find out. What axle?
Old Oct 12, 2006 | 09:36 AM
rearendman's Avatar
rearendman
What type of rear? Sounds like you ground up the gears? A real grovelling sound?
Old Oct 15, 2006 | 08:38 AM
HUCKSTER-USA
yea its a pretty sickening sound! almost as if the pinion isnt gettn a good bite on the ring gear. just got back into town and havent done anything with it yet. its a 9". seems to be gettn a good bite forward but spinning (under pressure) in reverse.
Old Oct 16, 2006 | 08:56 AM
rearendman's Avatar
rearendman
You need to remove the diff and look at it; I have seen people driving around with one broken main cap and ground up metal in the entire housing.
Old Oct 17, 2006 | 07:34 PM
kennethl6's Avatar
kennethl6
Is this a 4x4? If so, could be a transfer case problem.
