Aerostar Ford Aerostar
neutral safety switch
Old Oct 11, 2006 | 02:06 PM
Peter007's Avatar
Peter007
Van wouldn't start the other day. Wouldn't think a jump would work as all the lights and heater came on strong. Tried it anyway, but to no avail. Had problems starting earlier in the week, would only start in neutral. Do these sound like symptoms of a bad switch? Any help a +. Thanx.
Old Oct 11, 2006 | 04:27 PM
96_4wdr's Avatar
96_4wdr
welcome Peter007
yes, sounds like intermittent neutral safety switch aka shift lever position sensor
switch can fail or positioning needs to be adjusted
does it start ok in neutral but not in Park?
can test by jumpering wires red/lt. brn and white/pink on switch and seeing if problem goes away....if not=='s other wiring problems
Old Oct 11, 2006 | 04:29 PM
copper_90680's Avatar
copper_90680
Hi Peter:
Welcome to our FTE forum
Yes, your symptom does sound like the neutral switch, but it also be a problem with the linkage leading to the switch.
