morning start problem - white smoke
Old 10-11-2006, 02:00 PM
joemar81's Avatar
joemar81
joemar81 is offline
last two monings '02 7.3 w/125Kmiles has a problem starting. engine wants to start - but almost immediately just spins on the starter. White smoke from the exhaust. 1st morning I thought to drain the fuel filter and it then immediately started and ran fine thru the day w/ numerous starts. 2nd morning - same start problem. same routine w/ fule filter. started. I then removed cap on fuel filter, inspected, replaced same filter and it started. ??????????
Old 10-11-2006, 08:58 PM
kbeefy's Avatar
kbeefy
kbeefy is offline
have you checked out your glow plug system?
Old 10-14-2006, 03:35 PM
SVLERF250PWRSTRKE's Avatar
SVLERF250PWRSTRKE
SVLERF250PWRSTRKE is offline
mine smokes alot (white) too when first starting. But starts fine and mostly does it in cold weather. Dont know why
Old 10-14-2006, 06:46 PM
PSNut's Avatar
PSNut
PSNut is offline
I'll bet your glow plug relay needs replacing.
Nut
Old 10-14-2006, 06:53 PM
BowTieHatr's Avatar
BowTieHatr
BowTieHatr is offline
you could be having a fuel pump issue. check and see if your fuel is "bubbly" when you switch the truck on by looking in your filter housing with the filter out.
Old 10-14-2006, 07:07 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
Whoa, better give some better instructions than that. If you look in the fuel bowl with the filter out, top off, and turn the key on you're going to have a real mess. I'm sure that is not what you meant but someone might take it that way and try it.
Old 10-14-2006, 07:43 PM
BowTieHatr's Avatar
BowTieHatr
um yeah that what i meant. it wont make a mess unless you let it over flow. it would not be much pressure just flow. drain the fuel out of the bowl by the drain valve and watch thefuel come up in the bowl. let it come past the inlet before making judgement
Old 10-15-2006, 11:50 AM
Tenn01PSD350
No, I mean you probably wanted to tell him to have someone help that can turn the key on and off at command instead running back and forth in which case he may end up with a mess from not getting back in time before it overflows. I think between us now he should get the idea.
