"Check Gas Cap"
Old Oct 11, 2006 | 12:30 PM
Beefford's Avatar
Beefford
"Check Gas Cap"
Anyone know how to get this message your guage cluster? I don't know how the cap got loose, because the message came up after 3/4 of a tank of fuel had been run out - maybe someone tried to steal gas. Anyway does anyone know how to get rid of the message? Disconnect the battery?
Old Oct 11, 2006 | 01:25 PM
spiggy769's Avatar
spiggy769
I would think that if you had already tightened the Fuel cap and you still have the message coming up you might possibly have a pressure leak in your tank somewhere ...might even be a Bad Gas Cap. I would try disconecting the battery first for like 10-15mins then reconnecting it. If it doesnt clear then I would suggest dealer if still under warranty.
Old Oct 12, 2006 | 09:38 PM
Buck 1's Avatar
Buck 1
At times it may take up to 48 hrs. for the system to correct the display. As long as the cap is securely on now, the message should disappear within a day. If not, go to the local Autozone and they will be able to repost the code.
Old Oct 13, 2006 | 04:22 AM
7T9F250's Avatar
7T9F250
I believe Autozone is not authorized to clear codes. An employee may do it for you, but I think their policy prohibits clearing codes. I was told by Murrays that you can borrow their code reader and clear codes yourself.
Old Oct 13, 2006 | 07:09 AM
Beefford's Avatar
Beefford
The cap was found loose on Monday. It is now Friday and the message remains. I am going to disconnect the battery this weekend and see what happens. Truck has 36,800 miles - so no more trips to the dealer for me.
Old Oct 13, 2006 | 07:43 AM
osbornk's Avatar
osbornk
Autozone clears them all the time as does Advance. On my car, the gas cap problem turned out to be a leak in the charcoal cannister.
Old Oct 13, 2006 | 10:40 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I believe that that is part of the Emmisions Warranty and is longer than your regular 3yr-36000 mile warranty. Call your dealer, I believe that it will be fixed at no charge.
Old Oct 13, 2006 | 01:44 PM
7T9F250's Avatar
7T9F250
I had an O2 sensor I replaced on a vehicle,(check engine light was on) at my local autozone one person on the phone said they would clear the code, when I went there and asked them to clear the code, I was told they can get into trouble for doing it.
Old Oct 13, 2006 | 01:50 PM
spiggy769's Avatar
spiggy769
I didnt even think about that. I beleive the required Federal warranty on emissions is 8/80K so you would be covered. ANd It is an emissions problem if your Tank is not sealing correctly.
Old Oct 13, 2006 | 08:16 PM
Beefford's Avatar
Beefford
One more question - if I disconnect the batter would it be necessary to remove my tuner?
Old Oct 13, 2006 | 11:12 PM
spiggy769's Avatar
spiggy769
Just to be on the safe side I would return my vehicle to the stock tune...only takes a few minutes to be safe.
Old Oct 15, 2006 | 05:51 PM
jaym69's Avatar
jaym69
You can purchase the code readers for about $120 for a good one and be able to check and clear codes yourself. I bought one and it was a great purchase and very worth it.
