speedometer failed 98 ranger HELP!!
Old Oct 11, 2006 | 11:08 AM
olycarguy's Avatar
olycarguy
1998 ranger, ran battery low and now speeometer stopped working. replaced vvs sensor on rear axle, installed new battery and alt., and still having problems.... any thoughts?
Old Oct 12, 2006 | 06:29 AM
pawpaw's Avatar
pawpaw
Welcome to FTE olycarguy.
Well maybe the replacement VSS was bad!!!! Just because it was new, doesn't automatically make it good, I've seen bad parts right out of the box!!!!
As the speedo is electrically driven in this model, if you have a scan tool that'll read PID's, you could hook it up, drive the vehicle while monitoring the speedo signal & see if the computer is outputing anything to the speedo.
If not, sounds like maybe there might be something wrong with the wiring or a connector, from the computer to the speedo, the computer itself, from the VSS to the computer, or the VSS itself.
Do you have any trouble lights lit, like ABS or Check Engine lights, If so, scan the computer for trouble codes & see what it's unhappy with, may be a good clue stored there. If you have a ABS light on, that to me would suggest something is wrong with the VSS signal.
Let us know what you find.
Old Oct 13, 2006 | 11:14 AM
olycarguy's Avatar
olycarguy
thanks for the reply, we found the problem yesterday........bad connection at dash panel! Everything seems fine and the truck runs great. thanks for the help. T.H.
Old Oct 13, 2006 | 11:37 AM
pawpaw's Avatar
pawpaw
OK, good to hear you have it put right, good feedback too!!!
