turnsignals
Old Oct 10, 2006 | 10:29 PM
wheeler76's Avatar
wheeler76
Smile turnsignals
My turn signals do'nt work. There is no power to my round fuse.. Does it work off the fuse box?
Old Oct 10, 2006 | 10:35 PM
gbrett's Avatar
gbrett
I think the round fuse is your flasher
Old Oct 10, 2006 | 10:51 PM
Nod's Avatar
Nod
Turn Signal
wheeler 76,I think the round fuse you are looking at is the flasher unit that causes the lights to flash.Power comes up to the turn signal switch when the ignition switch is in the run position or in the ACC position.From there the switch sends power to the flasher unit and to the turn signal lights ,so first check to see if there is power at the plug in at the wire harness where the turn signal hooks to the main harness.Test each wire for power with the key in the ACC position and then with the key in the on position with the engine running.If power is found then there may be a problem with the turn signal switch itself or the wiring from the harness to the switch or the wiring to the turn lights.If no power is found at the harness plug then there may be a problem with the ignition switch,bad wiring or a blown fuse in the fuse box.Hope this helps.
"bowties in the reaeview mirror"
Onus
46
Jan 5, 2016 08:38 PM
GamerGirlAlice
Jul 8, 2013 06:13 PM
wrd0225
May 23, 2012 04:57 AM
mattisjd
1983 - 2012 Ranger & B-Series
Oct 13, 2004 09:56 AM
Beatlez
Jun 18, 2004 10:04 AM
