Fuel Additive???
Old Oct 10, 2006 | 09:21 PM
lwhitcomb's Avatar
lwhitcomb
Fuel Additive???
My pick-up goes unused for several months at a time. I have hade some fuel delivery problems, most likely, due to this. I know that the tanks should be full if it it going to sit for a while, but if it is going to sit for several months should I use a fuel additive? If so, does anyone know of a good one? Any other tips????
Thanks,
Ladd
Old Oct 10, 2006 | 09:46 PM
ltfox's Avatar
ltfox
Stanadyne is very good. I also like the Power Service additive.
Old Oct 11, 2006 | 12:18 AM
Learath's Avatar
Learath
since we are on the topic hows mmo for diesel use?
Old Oct 11, 2006 | 12:22 AM
PLC7.3's Avatar
PLC7.3
MMO works fine..................
Old Oct 11, 2006 | 03:03 AM
lwhitcomb's Avatar
lwhitcomb
Thanks guys. Are poly tanks a good idea for that application???
Old Oct 11, 2006 | 01:16 PM
Agemenon's Avatar
Agemenon
Diesel kleen is a good one.
Old Oct 11, 2006 | 06:45 PM
ltfox's Avatar
ltfox
MMO??????? Please enlighten me.
Old Oct 11, 2006 | 06:51 PM
Dave7.3's Avatar
Dave7.3
I believe MMO stands for Marvel's Mystery Oil...
Old Oct 11, 2006 | 07:04 PM
Learath's Avatar
Learath
yea thats the stuff, nice red color
Old Oct 11, 2006 | 07:17 PM
ltfox's Avatar
ltfox
gotcha!..........yet to used the stuff
Old Oct 11, 2006 | 11:27 PM
lwhitcomb's Avatar
lwhitcomb
Will these do the trick for when I leave it sit for several months??
Old Oct 12, 2006 | 12:20 PM
Agemenon's Avatar
Agemenon
Well petrol in general changes over time. Like if let gas sit for a while, all the sulfurous compounds will desolve and it'l eventually turn into water. Now diesel I'm not too sure about...because it's less refined I wouldn't be able to tell you what certain properties it has. Generally speaking you should put some of that stuff in the fuel tank and let your truck for about 20 minutes so that it can work its way into the engine. I think over time you should add more of it because it may desolve somehow and its effectiveness might lessen.
Old Oct 12, 2006 | 12:27 PM
AndysFords's Avatar
AndysFords
I'm not sure, but I do know that if you let diesel sit too long it will lose its lubrication. On the farm we put a quart of transmission fluid in our tractors tank when we will up to restore lubrication.
Old Oct 12, 2006 | 12:38 PM
Agemenon's Avatar
Agemenon
why would you put tranny fluid? why not just regular oil? wouldn't the tranny fluid do something to the fuel?
Old Oct 12, 2006 | 02:56 PM
bc6.9's Avatar
bc6.9
Andy, I understand it has been done for years but there's older post about "fuel additives" and goes into a long detailed account on "why" you shouldn't put tranny fliud into our tanks....Dave S or some one could explain it in detail, all I know for the price new injectors and an IP, we should stick with a proper "fuel additive"
