instrument panel lights
Old Oct 10, 2006 | 07:41 PM
therigwelder's Avatar
therigwelder
i have no instrument panel or cab clearance lights.fuses and bulbs good
Old Oct 10, 2006 | 08:44 PM
Dealford's Avatar
Dealford
So, the headlights and tail lights do work? You might want to pull the headlight switch & check it and it's plug for burnt/corroded connections & wires.
Did you use a test light at the fuse panel to check the fuses?
AL.
Old Oct 11, 2006 | 12:20 PM
therigwelder
yes head and tail work checked fuse with test light
Old Oct 11, 2006 | 07:03 PM
Franklin2's Avatar
Franklin2
Pull the headlight switch out of the dash, but leave it plugged in. Turn the headlights on, and get a testlight or voltmeter and see if you have voltage on the lightblue/red wire coming out of the switch. This is the wire that feeds voltage to the instrument light fuse, and then feeds the instrument lights.
