Starter Problem 2000 Xpy
Old Oct 10, 2006 | 07:16 PM
ozonelevel's Avatar
ozonelevel
Exclamation 2000 Xpy Starter Problem
2000 Xpy, 5.4L, 4WD, 85000 mi.
Starter began to occasionally not engage about a year ago. It would do it intermittently every once in a while (months) so it wasn't a big deal at first. Put in a new battery, heavy duty 850 cca March 05. Recently starter began to not engage more often, finally last week it did it twice in a row. Solenoid activates, starter turns, but gear misses flywheel and makes grinding noise.
OK, so today replaced starter. Seemed OK for about a half dozen starts, but just a while ago, it did the same thing. Battery seems OK, starter turns engine like a scalded dog once it engages.
Any ideas on what else could cause starter gear not to engage?
Old Oct 11, 2006 | 10:58 AM
MisterCMK's Avatar
MisterCMK
How do the teeth on the flywheel and the starter look?
Old Oct 19, 2006 | 08:35 PM
atoztech's Avatar
atoztech
I Agree Check The Flywheel For Chipped Or Missing Teeth
Old Feb 8, 2007 | 09:33 PM
ozonelevel's Avatar
ozonelevel
Replaced starter. Old starter gear teeth showed a lot of wear. Day after replaced starter, missed again once but has been ok for a couple of months now. Probably is chipped teeth on flywheel.
Old Feb 8, 2007 | 10:57 PM
wrenchturner's Avatar
wrenchturner
that's a downfall of the auto trans. no way to easily rotate the crank to get some good teeth exposed. to check'm i'd pull the spark plugs and put a ratchet on the crank in nuetral. have a friend watch or turn. but block the wheels.
Old Feb 8, 2007 | 11:23 PM
MisterCMK's Avatar
MisterCMK
Just put a breakerbar on the crankshaft. You don't need to put in neutral at all, just turn it.
