Need A Autocad Guru
Old Oct 10, 2006 | 06:57 PM
4tl8ford's Avatar
4tl8ford
Need A Autocad Guru
I have a planform of a 1946 Ford Chassis that I need on Autocad.
The palnform is two view from side and from top with some basic dim.
I am going to be converting this chassis to a speedster chassis and I need to be able to move things aroung.
TIA
Dick
Old Oct 10, 2006 | 08:15 PM
DetailerDave's Avatar
DetailerDave
So what is your question? How to move the items? Or do you want someone to draw them up in AutoCad?
Old Oct 11, 2006 | 04:01 AM
4tl8ford's Avatar
4tl8ford
If I can understand the instructions I'll do it, If my old mind fails I'll need some help.
Dick
Old Oct 11, 2006 | 05:27 AM
DetailerDave
OK, just give a holler if you need some assistance.
Old Oct 11, 2006 | 07:42 AM
rebocardo's Avatar
rebocardo
If you do not know how to use Autocad why not use something easier and cheaper such as Visio?
Old Oct 11, 2006 | 10:32 AM
4tl8ford's Avatar
4tl8ford
I have autocad and have used it on autocad specific items. I haven't imported a scan in a way that I can use it.
Old Oct 11, 2006 | 10:35 AM
DetailerDave
I have a program that I use to convert pdf's, etc to dxf so I can import them into my Cad programs.
Old Oct 11, 2006 | 11:05 AM
MisterCMK's Avatar
MisterCMK
visio can't even compare to autcad. The learning curve is a little steep if you want to do more advanced things with autocad, but for simple drawings its fairly easy.
Old Oct 11, 2006 | 11:10 AM
loudfords's Avatar
loudfords
Putting a scan into dxf into autocad will likely just result in lots of little line segments. You can import the scan and then trace it with a polyline - then you can put some things in blocks to move them around.
Old Oct 11, 2006 | 11:30 AM
Steve_B's Avatar
Steve_B
As loudfords said, converting pdf's or any other picture to a CAD drawing format is difficult
Coreldraw can do it but you will find it easier to import the picture as a background image then trace over it using the Autocad drawing tools
Old Oct 11, 2006 | 12:17 PM
DetailerDave
Yep- That it does. All I use it for is the general drawing so I can add markings to it without having to redraw the whole thing.
Old Oct 11, 2006 | 01:19 PM
4tl8ford's Avatar
4tl8ford
Thanks I'll play around with some of those suggestions.
Old Oct 12, 2006 | 10:23 AM
rebocardo's Avatar
rebocardo
You get what you $ for :-)
I have not fooled around with CAD programs for a while, BUT, if you can find something that converts from a JPEG to .SVG or something it might work better then importing a graphc and drawing over it. Especially if it allows you to group segments to form objects.
What you have does not sound too tough to trace though.
I think OEMs should release vector graphics to the public so people can designed parts more easily or modify their vehicles. I know SEMA members probably have access to this stuff, just would be nice if everyone else did too.
Old Oct 12, 2006 | 08:41 PM
4tl8ford's Avatar
4tl8ford
While I was looking for an SVG converter I found this.
http://www.inkscape.org/
So far it looks and acts much easier then CAD
Old Oct 13, 2006 | 12:00 PM
dumptech's Avatar
dumptech
I've had to use scanned files many times. I find that .jpg files work well if you import into AutoCAD as a raster image and scale it to the proper size (calculate by drawing a line the same size as one of the dimensions and figure out the scaling factor). Trace the lines of the scanned image on a seperate layer. and go from there. I've used some files that were vectorized from scans and found them to be quite large because the vector image is all small lines that eat up huge amounts of memory. Just recently I used a file that was vectorized from a scan. The original vectorized file was over 13 mb. I traced the lines with the plygon tool in AutoCAD and the new file ended up less than 1 mb. Let me know if you need any more help with AutoCAD. I've been using it for about 10 years (civil engineering mostly.) Good luck
