Overdrive for '53 and kingpin bearing kits
Sorry for the double question. Have a '53 F100 which is cherry, but 50 yrs old. About as original as it gets.
Number one, I see that while my truck has a simple 3 speed, a 3OD was available. I need one! Any info on where one of these units might be available to add-on, or what other cars/trucks had similar units that might bolt up?
Number two, I see rumors of a needle bearing replacement for kingpin bushings. Where can I find these for my '53, and are they worth the extra expense??
Thanks!!
Thanks!!
OD for a Slant Cab
Thanks!!
Thanks!!
I have never heard of Needle bearing Kingpin bearings. Be aware that there are ways to attach rack and pinion steering gears to a beam axle, and if you keep the engine weight down standard kingpin bushings and a manual rack will do very well on a beam axle.
Regards,
Alanco
Will do. I'm hoping to find just the OD unit itself to add on, so do I understand correctly that a passenger car unit will fit? Also, the truck has been converted to 12V, so I'm assuming I want a 12V unit.
One main concern with the standard type kingpin bushings was the ability to install them. I keep seeing people imply that they require machining and other problems. I'm keeping the stock 215 6cyl., so weight isn't an issue. Was planning on a disc upgrade but stock steering with rebuild...
After I sandblasted all my front axle parts, I took to a front end shop and they ordered +0.010 oversized king pin kits that included bushings, bearings, pins, etc. The kit was about $170 and the labor to ream the holes was about $75. $total bill was around $250 or so.
Well worth it. the steering is absolutely tight and works like new.
They honed the holes with a Sunnen front end hone and everytthing fit perfectly.
Don't try to "cheep' it out. it's not worth it! They can also set camber, toe-in etc. That's worth it too.
I'm also considering a Gear Vendors unit for my OD. Those are not cheep at all....you might just consider a different ring and pinion.
Regards,
Rick
Regards,
Rick
Brakes and things..........
I don't feel that disc brakes are necessary on an F-100 with a light engine, as the stock brakes are Bendix self energizing drum brakes. If the brakes are in good condition, they are entirely adequate.
Regards,
Alanco
Thanks for the advice. The brakes have apparently recently been overhauled, but are still a little shaky. Likes to pull to one side or the other. That may be a steering issue, I suppose, I'll see when I tear it down. I had considered a different rear-end, also, but I like the low 1st and second around town, they work well with the relatively low-powered 6. I'll look up Gear Vendors, too. I just haven't seen much on OD's with Google searches.
66crawler
03-13-2012 03:01 PM
F350Fummins
12-27-2011 02:22 PM
Kelpy1
09-06-2011 02:43 PM
whalerron
11-10-2004 09:46 PM
