9" in a 65????
Old Jul 16, 1999 | 04:16 PM
Phat65's Avatar
Phat65
9" in a 65????
i wanna put a 9 inch in the 65 f 250 i have what donor vehicle will give me a good start
Old Jul 16, 1999 | 05:38 PM
jason's Avatar
jason
9" in a 65????
If you're really wanting to swap in a weaker rear end than what you've got, look for a 1964 or later rear end out of a F100 or F150. The heaviest rear is rated for 3300 lbs. Use the axle tag and/or outer axle bearings for identification. You'll probably have to relocate your spring perches, possibly lengthen the driveshaft, buy a u-joint to adapt from your 3/4 ton driveshaft to the 1/2 ton rear, and adapt the brake lines. By the way, you're also getting smaller (weaker) brake shoes. Good luck!
Old Jul 18, 1999 | 08:42 AM
Tim
Guest
Posts: n/a
9" in a 65????
The question really is if you want to make a half ton truck out of a 3/4 ton truck. 9 inch axles are good axles, but the axle under your truck now, probably a Dana 60, is definatly stronger, and is generally cheaper to modify.
Old Jul 18, 1999 | 07:00 PM
jason's Avatar
jason
9" in a 65????
65 Econoline
Nov 20, 2016 09:00 AM
Amphihauler
Oct 1, 2016 07:54 PM
whateverittakes
Feb 11, 2016 02:15 AM
Danp65
Dec 3, 2015 09:32 AM
vincel1965
Dec 13, 2012 04:13 PM
