Generator
Old Oct 10, 2006 | 07:41 AM
schlichtemeier's Avatar
schlichtemeier
Generator
Last year hunting I just about didn't get my PSD started one morning. I have a 500 W generator and I was thinking about taking it along just in case it got real cold again. Is this a good idea? If so, is 500 W big enough to do the job?
Thanks, Chad
Old Oct 10, 2006 | 07:44 AM
cangim's Avatar
cangim
If you have a battery charger that will charge the batteries with it, not a bad idea at all. Me personally, I would check the age on the batteries, might think about replacing them. Also, was your truck just sitting there or are you using it to power lights in a trailer or the like? If you are worried and have the space for the generator, why not take it?
Old Oct 10, 2006 | 11:23 AM
kbeefy's Avatar
kbeefy
is it 500 or 5000(5kw)? A 500 would almost fit in your pocket and run a small charger, but is only 1/2 of what you need to run your 1000w block heater.
Old Oct 10, 2006 | 12:09 PM
Pony Power's Avatar
Pony Power
I always plug mine into the genny when we are up on the hunt. I also have one of those magnetic heat blocks stuck on my oil pan as a backup. We had a problem one year and don't plan on a repeat that deal.
Nothing like jumping into a warm truck that starts right up when it's in the teens.
Old Oct 10, 2006 | 12:23 PM
schlichtemeier
It is 500 w. Little bigger than my pocket, but it is compact. If the block heater takes 1000w, will 500 w not even turn it on or will it just take twice as long?
thanks, Chad
Old Oct 10, 2006 | 12:35 PM
Uzumati's Avatar
Uzumati
As soon as you plug the block heater in it will "pop" the breaker on the Generator, the startup current draw on a 1000w heater is closer to 2200w
Old Oct 11, 2006 | 12:06 AM
kbeefy's Avatar
kbeefy
how cold is it? as mentioned earlier, make sure your batteries are up to snuff. If everyting is working well it should start down to 0. I do it snowmachining all the time.
Old Oct 11, 2006 | 09:08 AM
schlichtemeier
Last year it got down around zero. I got up in the middle of the night just to make sure it would start. Still struggled in the morning starting. Since then, I switched to 5-40 synthetic, which seems to help a lot. I am going to replace the batteries before I go because I think they may be part of the problem. I guess I am paranoid!
Thanks, Chad
Old Oct 11, 2006 | 11:57 AM
Pony Power's Avatar
Pony Power
Make sure you have a good working GPR in there also. It could be your cold weather starting problems if its not doing its job.
