HELP mpg gone !
Old Oct 9, 2006 | 10:25 PM
ktahelton's Avatar
ktahelton
HELP mpg gone !
fuel filter drain was leaking on my 99 couple weeks ago so i put new o-rings in it had the fuel filter out while i was workin on it and after i put it back together no more leaks but mpgs went south too. anybody got any ideas?
Old Oct 9, 2006 | 10:35 PM
clux's Avatar
clux
Is it possible that your fuel bowl repair coincided with the stations changing over to winter fuel in your area?
I know my mileage takes a dive about this time of year when winter blend arrives.
Old Oct 10, 2006 | 08:31 AM
Kwikkordead's Avatar
Kwikkordead
This might sound like a stupid question, but are you figuring fuel usage while you had the leak? Or are you sure that you fixed ALL the leaks?
Old Oct 10, 2006 | 08:45 AM
powerstrokin007's Avatar
powerstrokin007
Let me ask you this, would Diesel Kleen help in this situation? It would be in the white container, right?
Old Oct 10, 2006 | 08:53 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
The white bottle has the anti-gel additive, use the grey bottle.
Old Oct 10, 2006 | 09:06 AM
wolfe1104's Avatar
wolfe1104
I had a similar situation, I started using the gray bottle of DK and so far im getting around 1.5 mpg better.
Old Oct 10, 2006 | 01:46 PM
clux's Avatar
clux
I havn't found any additive that will take my mileage on winter blend back up to what I get on summer fuel. It's simple, there's less energy in a gallon of winter blend, so mileage suffers.
Old Oct 10, 2006 | 10:38 PM
ktahelton's Avatar
ktahelton
well kwik i cant seem to find any more leaks ,and ive always run gray diesel clean in my truck if not every tank atleast every othe tank. as far as the diesel blend ive never seen any diff. in summer and winter blend as far as mpg's go in my truck...think ill pick up anew filter tomorrow and see what that does. but thanks for all your help every!one
Old Oct 10, 2006 | 10:42 PM
ktahelton's Avatar
ktahelton
on a nother note, my boost seems slow on the low end and taking off any ways to work that over?
