Idle speed low & ck.eng light
Originally Posted by xtrm1stang
p1504? or p1507?, the throttle body motor is weak and cannot hold an idle due to the pull of vacuum, replace the throttle body.
Cleaning it sometimes hemps but be prepared for replacement.
Reset the PCM after working on the IAC to force the computer into a relearn cycle. Pulling the PCM KAM fuse for 10 minutes will do it.
Steve
Funny, I guess I don't know what I'm talking about, try to find the iac and clean it, but when you cannot find one, you'll be replacing the throttle body because the truck has an electronic throttle body, which controls idle and throttle. Maybe he should check the throttle cable end play too!!!
I like your ending by the way.
Ignorance can be addressed thru education.
Unfortunately, you cannot fix stupidity.
Education works, so does experence, both in which I have alot of !
capstan
04-14-2005 07:31 PM
