35's with a 2.5 leveling kit?
Old Oct 9, 2006 | 09:58 AM
stevelacey75's Avatar
stevelacey75
is anyone running 35's with a 2.5 lveling kit? i would like to see pics. i have 33's on aftermarket wheels and think they look a little small.
Old Oct 9, 2006 | 11:39 AM
double06's Avatar
double06
Hey, I got almost the same setup as you. I got a 20x10 wheel with 33x12.50 Nitto's (05 SCREW). I have the 2.5 AS leveling kit and mine rubbed a little. I had to trim some of that molding right below the bumper and some of the factory fender flares. I can't see how a 35 would make it without significant rubbing. Might have to add a body lify also to make that work. I know my buddy had the same setup with the 35's on a 20in wheel and he ended up haveing to lift the body. Just my .02
Old Oct 9, 2006 | 11:41 AM
04FX4Me's Avatar
04FX4Me
I think the reason your 33's were rubbing was because you have a 10 inch rim. I have 18x9 with 35x12.50s and have no rubbing. If anybody can tell me how to post a pic i'll post mine.
Old Oct 9, 2006 | 11:48 AM
double06's Avatar
double06
Yup, Agree with above! I think its safe to say that if you have a 10in wheel with 33's - 35's you are gonna get some rubbing. Ditto on the tell me how to post pics!
Old Oct 9, 2006 | 01:16 PM
Cavtrooper06's Avatar
Cavtrooper06
With your picture you have two options: 1) Upload it into your FTE gallery and once its done right click on it choose properties to find the URL, then when you post click on 'Go Advanced' and on the toolbar with be a picture icon, click on it paste in the URL and your set, 2) Upload your picture to a some sort of hosting site and then right click on it choose properties to find the URL, then when you post click on 'Go Advanced' and on the toolbar with be a picture icon, click on it paste in the URL and your set.
You'll then have this:
Old Oct 9, 2006 | 02:12 PM
double06's Avatar
double06
OK, I'll take a SWAG at it.. (its kinda dirty but... thats how a truck should be! Right??!!!)
Old Oct 9, 2006 | 04:01 PM
stevelacey75
i have terra grepplers 33x12.5 on a 20x10 and they dont rub at all. i have quit a bit of room left. ill try to takes some pics.
Old Oct 9, 2006 | 05:53 PM
04FX4Me's Avatar
04FX4Me
hope this works but i got 18x8 and 35x12.50 BFG Mud Terrains
Old Oct 9, 2006 | 06:56 PM
stevelacey75
heres a pic of how much room i have.
Old Oct 9, 2006 | 10:32 PM
Hollywood2005's Avatar
Hollywood2005
I put in what they call a 3" lift with 35's (see gallery) and have no rubbing after some very minor trimming. I am running Copper tires right now but did try running the same size Nitto tires but had major rubbing. The Nitto tires are at least a 1/4 to 1/2 inch taller and wider.
So I would have to say dont run the Nitto Tires with the 2.5 inch lift
Old Oct 10, 2006 | 04:26 PM
JRFX4's Avatar
JRFX4
I am running 33x12.50 17's on AE wheels. My local truck shop said you can put 35's but on a wheel that keeps the tire tucked in close to the truck. I chose to stick w/ 33's, 35's are a lot of wear/tear on a half ton suspension/steering system. Plus the bigger you go the more you change your gear ratio.
Old Oct 10, 2006 | 05:11 PM
F0rdFre@K's Avatar
F0rdFre@K
I ran 35s on a 99 Wrangler with stock axles/steering/gears. Only thing I changed was my suspension. I can't see 35s being overly agressive on my 05 F150. Much heavier duty setup then a 1/4 ton Jeep.
Old Oct 10, 2006 | 06:57 PM
triple8's Avatar
triple8
I had 35's under my '83 CJ 7, with 4" Tral Master lift. It had stock AMC rear 20 just one piece shafts anf an Auburn locker, and the stock dana 30 up front. I swapped in 4.10 gears, it also had a massaged AMC 401 V-8 pushing the rig. Never any issues with the drive line. 35's and issue on a stock half ton I seriously doubt it.
Old Oct 10, 2006 | 09:46 PM
stevelacey75
4 inck lift with 35x 12.5 on my old jeep and never had a prob.
Old Oct 11, 2006 | 08:59 AM
JRFX4's Avatar
JRFX4
FordFre@k, Triple8, & stevelacey 75, ya'll may be correct, but where those rigs everyday drivers?
