1965 Automatic
Old Sep 12, 1999 | 07:22 AM
Russell Leonhardt's Avatar
Russell Leonhardt
1965 Automatic
How much trouble is it to convert a 3-speed to a automatic on a 1965? I found a 1967 automatic column and will this bolt up to my dash? Also can I change to power steering and what years will bolt up? I have the truck disassembled and I think it would be crazy to put it back 352,3-speed with no power steering.
Old Sep 12, 1999 | 12:44 PM
jowilker's Avatar
jowilker
1965 Automatic
Russ, it's not too hard to make the swap, I'll agree it's crazy not to add power steering as well, any thing through 79 will work. I'd put disks on the front as well while you got it down.
John
Old Sep 13, 1999 | 08:41 AM
frank_1's Avatar
frank_1
1965 Automatic
from what i understand the steering column will bolt direct, it may or may not plug into the factory wiring. i do not know which engine you are considering using. if you plan on using the 352 for the truck, i would certainly recommend it as an excellent motor. the 352 will give you real nice low end torque and it is a little better on gas than the 390. an rv cam and a four barrel will really bring the 352 to life! ...good luck
Old Sep 14, 1999 | 06:03 AM
StockMan's Avatar
StockMan
1965 Automatic
