brake light problems
Old Oct 8, 2006 | 07:32 PM
superdutyranger's Avatar
superdutyranger
77 f 150 -every light on the truck works with exception of brake lights.power to switch is fine,replaced switch.flashers only blink on front of truck.no rear flashers,no brake lights.any suggestions?p.s. grounds are all clean
Old Oct 9, 2006 | 06:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
Welcome to FTE!
First off we will get you to the right forum: 73-9 trucks.
Next, no rear flashers or brake lights would indicate a problem with the column switch. Check your service manual and test the turn signal column switch.
