vent
Old Oct 8, 2006 | 04:44 PM
lartross's Avatar
lartross
vent
Is it normal to have heated air coming out in "vent" mode? Does it normally flow over the heater coil in vent mode?
Old Oct 8, 2006 | 05:49 PM
1978fordf250's Avatar
1978fordf250
depends on if you have the hot or cold switch on hot ifit is on the hot side it will be hot if it is on cold side it will be cold. (thats what i think it is) thats how mine seems to be)
Old Oct 8, 2006 | 07:14 PM
lartross's Avatar
lartross
I have the thermostat [?][temp select] on as cool as it goes...is that what you mean?
Old Oct 8, 2006 | 10:25 PM
PLC7.3's Avatar
PLC7.3
What ever temp you want out of any location, you have to select the temp. Your temp cable could be out of adjustment too.......
Put some truck info in a signature please................
Old Oct 9, 2006 | 11:10 AM
lartross's Avatar
lartross
I had a perfectly good signature for awhile and it dissappeared! I've tried to turn it back on..and I can't see any other non-paying members sigs, either. I started using firefox. Could that cause this problem? Anyway, it's a 1990 F250, 2x, E40D, na...in process
Old Oct 9, 2006 | 05:55 PM
tjc transport's Avatar
tjc transport
i ain't rite
your signature will not show till you have over 25 posts.
