Stator removal and installation
Old Oct 8, 2006 | 04:33 PM
87fomoco's Avatar
87fomoco
How do i replace the stator in my 87 f150 5.0 ? Do i have to remove my distributer?
Old Oct 8, 2006 | 08:55 PM
water 5's Avatar
water 5
yes, and you will need to pull off the gear at the bottom and you will be able to pull the center shaft out and then you will be able to get to the stator make sure you make a mark from the bottom of the shaft to the gear you will have to press the gear back on with a press and put the role pin back in and it not easy to get it lined up .
