torque specs 02 2.3 dohc
Old Oct 8, 2006 | 03:15 PM
customkir's Avatar
customkir
I'm having a problem verifying torque spec on the head bolts for my 2.3 liter dual overhead cam 4cyl . i dug up a haynes manual that gives me specs in inch lbs ? its a 2002 ranger and uses the torque to yield type bolts. if it's inch lbs so be it i guess but the old ones certainly were tighter than 89 inch lbs coming off. Anybody have better info, plaese post.
Old Oct 8, 2006 | 03:49 PM
Bob Ayers's Avatar
Bob Ayers
First, welcome to FTE!!!
The torque spec in inch-lbs is probably for the valve cover bolts, not the head bolts.
Old Oct 8, 2006 | 04:33 PM
customkir's Avatar
customkir
sorry my initial glance was a little off. the book gives 5 stages 44inch lbs, 132inch lbs, 33 foot lbs 90 degree turn, angle tighten another 90 degrees. 33 foot lbs still sounds a little low but better than inch lbs
winchesterjjfb
Nov 1, 2025 12:04 AM
Ryan50hrl
2004 - 2008 F150
Aug 18, 2019 12:18 PM
BADBLUEOVAL351
Nov 23, 2011 11:28 AM
minnesotasix
4 Cylinder Engines
Oct 11, 2005 11:36 PM
eatmgrits
Aug 23, 2005 07:44 PM
