clutch peddle pressure
Old Oct 7, 2006 | 12:05 PM
fordtrkr's Avatar
fordtrkr
I have a 2000 F-150, my peddle pressure is fading away. If I pump it several time I get enough to start shifting at stoplights I have to keep pumping the peddle. Someone told me it sounded like air got in the system. Does the clutch cylinder have a bleeder valve like the brakes?? Or will I have to remove the master cylinder system from the truck to do it? I had my son pump the peddle and fluid is coming out the small hole on the cap of the reservoir. If anyone knows whats going one or if its something else I would appreciate any advice.
thanks,
Matt
Old Oct 7, 2006 | 12:13 PM
andym's Avatar
andym
The bleed screw is on the tranny, just above where the hydraulic line goes into the bellhousing. Just bleed it like you would brakes.
