Sponsored by: Auxito
Clutch peddle pressure
Old Oct 7, 2006 | 09:31 AM
fordtrkr's Avatar
fordtrkr
Question Clutch peddle pressure
I have a 2000 F-150, my peddle pressure is fading away. If I pump it several time I get enough to start shifting at stoplights I have to keep pumping the peddle. Someone told me it sounded like air got in the system. Does the master cylinder have a bleeder valve like the brakes?? r will I have to remove the master cylinder system from the truck to do it? If anyone knows whats going one or if its something else I would appreciate any advice.
thanks,
Matt
Old Oct 7, 2006 | 09:47 AM
GammaDriver's Avatar
GammaDriver
thanks,
Matt
Sorta does sound like air in the system, but...
The bleeder I know of is from the slave cylinder - the other end.
And, FWIW, I have a '99, and I had to replace my clutch master cylinder over a year ago - you may be due.
Old Oct 7, 2006 | 10:01 AM
fordtrkr's Avatar
fordtrkr
I had my son pump the clutch peddle and brake fluid is coming out of the small hole in the cap of the reservoir.
Old Oct 7, 2006 | 01:34 PM
LxMan1's Avatar
LxMan1
I believe that these are a self bleeding system. Look in the belhousing area for leaks. You may have a bad master cylinder if there are no leaks and it is pushing fluid out of the cap.
