Oil Report
Old Oct 6, 2006 | 11:09 PM
Uzumati's Avatar
Uzumati
Oil Report
First Analysis from Blackstone. I feel better now ready to mod away (More)
Old Oct 6, 2006 | 11:33 PM
powrstrkn''s Avatar
powrstrkn'
Cool.
I don't know that I've ever seen a bad report on a Powerstroke on here or anywhere for that matter.
Old Oct 7, 2006 | 09:40 PM
JOE-M's Avatar
JOE-M
I have one question, why is the Moly so high? Just wondering.
Joe
Old Oct 7, 2006 | 09:46 PM
Uzumati's Avatar
Uzumati
http://www.blackstone-labs.com/gasol...port_expl.html
Molybdenum : Anti-wear additive, coating on some new rings
(washes off as break-in occurs).
No motor work ever done I guess at 85K shes not quite broke in yet
Old Oct 7, 2006 | 09:47 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
good catch. my report says 4ppm. the paper says that molybednum is an anti-wear additive, and is in some types of piston rings. so i guess that's good having a high number.
TwelveAlpha's Avatar
TwelveAlpha
I have 2 questions.
Whats an analysis like that cost ya,
And Joe, whats a zoodad mod (like I need to spend any more!)
Old Oct 7, 2006 | 09:54 PM
Uzumati's Avatar
Uzumati
ZooDad is FREE. Cut a whole in the bulkhead in front of the airbox snorkle to let more air in
Old Oct 7, 2006 | 09:58 PM
PowerstrokeJunkie
well, the report is $20, and the sample kit is free. the TBN (total base number) factor that determines the amount of "stuff" left in the oil is $10, and i got it.
a zoodad mod is free, plus a discount. its a hole that you cut in the radiator supports on either side, that scoop air into the radiator. it allows a straight path to the filter. take a look.
Old Oct 7, 2006 | 10:10 PM
Uzumati's Avatar
Uzumati
Tell them you heard about it on the Other (TDS) forum and its only 18 bucks
Old Oct 7, 2006 | 10:13 PM
JOE-M's Avatar
JOE-M
I think that Moly is also an additive in some oils. I run Rotella and the analysis from Oilguard is "0" on mine. I was just wondering if Chevron oil was loaded with it or something.
Joe
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Can you do the Zoodad with a sabre saw? What do you have to remove to get to the spot where you make the cut?
Old Oct 7, 2006 | 10:16 PM
JOE-M's Avatar
JOE-M
Take the grill off and you'll have plenty of room to work. A few screws at the top and snaps at the bottom. I cut mine with a hole saw and then connected the two holes with a saber saw.
Joe
Old Oct 7, 2006 | 10:18 PM
Uzumati's Avatar
Uzumati
Just remove the front grill, I used a rotoZip & I think Kris used a die grinder. it will be kinda tight in there with a sabre saw
Old Oct 7, 2006 | 10:20 PM
Uzumati's Avatar
Uzumati
Joe I am not sure how much moly delo has but my plan is to run 3 changes of delo and then 3 changes of rotella and whichever has better numbers I will stick with
