Sponsored by: Real Truck
gauge lighting
Old Oct 6, 2006 | 09:33 PM
993/4ton's Avatar
993/4ton
gauge lighting
I have just installed a 3 gauge A-pillar pod on my 1999 F-250. I do not know where to connect the hot side of the lighting circuit on the new gauges. I checked the back of the headlight switch, but it is a nice harness, and without wiring schematics, hopeless. So, my question is, where can I find a wiring diagram, or, does anyone know off hand which wire is the right one? Thanks.
Old Oct 6, 2006 | 09:59 PM
BigRyanKP's Avatar
BigRyanKP
just use a test light, *** probe the plug and find the wire that powers the dash and make sure it is the one that dims when you adjust the dimmer so your gauges dim with the rest of the lights.
Old Oct 6, 2006 | 10:06 PM
ReAX's Avatar
ReAX
1999 Ford F Series Stereo Information
Constant 12V+ Light Green/Pink
Switched 12V+ Black/Purple
Ground Black
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 6" x 8" Doors
Left Front (+) Light Blue/White
Left Front (-) Orange/Light Green
Right Front (+) Dark Green
Right Front (-) White/Light Green
Rear Speakers 6" x 8" Rear Door
Left Rear (+) Tan/Yellow
Left Rear (-) Gray/Light Blue
Right Rear (+) Brown/Pink
Right Rear (-) Orange/Red
Also
<table align="center" bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="1" width="100%"><tbody><tr bgcolor="#dddddd" valign="top"><td class="spce">Parking Lights</td> <td class="spcel">Brown (+) </td> <td class="spcel">Driver's Kick Panel or Light Switch </td></tr></tbody></table>
Old Oct 6, 2006 | 10:24 PM
Bear Hunter's Avatar
Bear Hunter
Blue with Red Tracer
Old Oct 6, 2006 | 10:39 PM
ReAX's Avatar
ReAX
Yep, that's the one I used on my 2002 as well.
Old Oct 6, 2006 | 11:09 PM
993/4ton's Avatar
993/4ton
does the headlight switch panel just pop out?
Old Oct 7, 2006 | 12:05 AM
Bear Hunter
Yep... you can see the metal tabs in the pic. You can either pull it out or reach up underneath and push it out.
