Tire Pressure recommendations
What is the recommended pressure to run on the 275/70 18 "E" loadrating when the truck is empty. The max is 80 PSI, which is way too much for an empty truck. What do you guys run?
Dave
Go to the Rubber Manufactures Association website here
http://www.rma.org/publications/tire...cationID=11309
Then click on the Adobe Acrobat file named
"Replacement Guidelines for Passenger and Light Truck Tires"
Then go to page 23 and at the bottom of the page it lists the load carry capacity of that tire size for air pressures from 35-80psi. You can use this as a guide to help you air down when empty.
Hope this helps
I run 70% in Rear.
Translation, 72lbs in Front and 56lbs in rear.
The truck handles well, tracks well and the tires seems to wear well. Provided I let my wife drive the truck.
Her foot is much lighter than mine.
