engine oil?
Old Oct 6, 2006 | 11:05 AM
uvbensmoked's Avatar
uvbensmoked
engine oil?
i just bought a 96 psd and its a little low on engine oil. can i just add oil or do i have to drain it and replace it? the oil looks farley clean so i dont want to change it all. also what oil should i use? i live in New Jersey and it dosent get under freezeing here for a little while.
Old Oct 6, 2006 | 11:21 AM
Cuda_jim's Avatar
Cuda_jim
Yep, you can add, no need to change it all out. Use diesel rated oils for the engine.
I would change all the fluids in the truck just for piece of mind. Good way to get to know your PSD. Search around this site for any questions you have or just post them here. There are many knowlegeable members on the site.
Old Oct 6, 2006 | 11:27 AM
utahcrew's Avatar
utahcrew
cuda_jim is 100% correct. I would just like to add try to find what type of oil is in there now, and use the same stuff. (I like to keep things consistant). Keep smokin
Old Oct 6, 2006 | 12:54 PM
uvbensmoked
thanks for all the help. and i plan to be smokin more when i get my dp-tuner
