leaf spring bushings
Old Oct 5, 2006 | 09:42 PM
jaydgraff's Avatar
jaydgraff
I removed my old bushing from my 66 F-250 there was the outter metal ring that contacted the leaf spring eye, that was destroyed when removed. My Question is. If I am installing poly bushings do I need the outter ring or can I just slip(more like press, they are pretty tight) the poly bushing in and call it good?
Old Oct 6, 2006 | 07:38 PM
Pickupmanx2's Avatar
Pickupmanx2
Slip it (press it) in and call it good, I was told by granpa that it was there to protect the rubber,,,, works for me, that is how mine are.
Old Oct 6, 2006 | 08:16 PM
66 POJ's Avatar
66 POJ
I replaced mine also and the metal ring should come out when replacing the rubber type with the poly ones.
Old Oct 6, 2006 | 09:26 PM
jaydgraff's Avatar
jaydgraff
So I dont need to use the outter meatal ring? RIGHT
Old Oct 6, 2006 | 11:51 PM
airharley's Avatar
airharley
Correct, the stock style bushings are there to assist pressing the soft rubber bushings into your leaf spring eyes.
