parking break light on
Old Oct 5, 2006 | 07:44 PM
aboehler's Avatar
aboehler
Hi,
I have an 89 F150 and the parking break light is constantly on.
No the parking break isn't engaged and I checked under the dash but couldn't find an loose cable or anything unusual.
Any idea what's going on?
Thanks
Alex B.
Old Oct 5, 2006 | 08:32 PM
subford's Avatar
subford
Sounds like you have a brake line that is leaking or a blown wheel cylinder.
Check the fluid in the master cylinder.
Old Oct 5, 2006 | 09:13 PM
aboehler's Avatar
aboehler
The braking system works fine though. The front brakes work fine and the rear brakes engage and disengage just fine. It's just the light in the cab that is constantly on.
Sorry if i wasn't clear before.
Alex B.
Old Oct 5, 2006 | 10:46 PM
EPNCSU2006's Avatar
EPNCSU2006
Make sure all the wires on the brake master cylinder are making good contact with the float switch. I had a constant ABS light that ended up being just a loose wire.
Old Oct 6, 2006 | 06:26 AM
subford's Avatar
subford
Alex B.
Do you have ABS system?
If no than it could be any of these items:
1. Parking Brake Switch Closed, misadjusted or shorted (defective).
2. Dual Brake Warning Switch not reset to center.
3. Ignition Switch shorted in bulb test area.
4. A Brake Indicator wire shorted to ground.
You were clear it is just that these are the common things that cause it.
